IP based Quality of Service
Feb 16th, 2010
I wan't to configure my Catalyst 3750.
My network is: /16
There 4 different sections
1. - 255 for Server's
2. - 255 for IPMI Interface's
3. - 255 for Client's (1)
4. - 255 for Client's (2)
I have created 4 ACL's
access-list 1 permit
access-list 2 permit
access-list 3 permit
access-list 4 permit
and 3 class-map's
class-map match-any remote
match access-group 1
match access-group 2
class-map match-all software1
match access-group 3
class-map match-all software2
match access-group 4
and 1 policy-map
policy-map marker
class remote
set ip dscp 1
class software1
set ip dscp 2
class software2
set ip dscp 3
I have add the policy-map to any Interface of the switch, because later I wan't that the clients
interface ....................
service-policy input marker
Now, all packets from the definied "areas" of my network are marked with a specific dscp value. But who can I configure Queues that match on the different dscp values?
My goal is that the Packets from Client's (1) always have 60% of the whole bandwidth guaranteed, Packets from Client's (2) 30%, and Packets from Server and IPMI 10% together. I also wan't, when the Client's(1) don't send packets, the other Applications(Server, IPMI, Client's(2)) have the full bandwidth and not only 30% or 10%. Clearly bandwidth guarantee and not a limitiation.
I hope you understand my question.
peterderk Wed, 02/17/2010 - 01:40
Oh there is a problem. When I give an interface the policy map then pop up a error.
That means, only one match per class-map is supported !
When I erase one of the entrys in class-map remote like:
Then is all Ok and the error are not pop up.
Inside the 3750 are only 2 Queues for QoS, but I need 4 different settings. Has anybody a Ideafor a solution?
Related Content
