reg:3560 switch
Feb 16th, 2010
Dear sir,
I have cisco 3560 switch and i have 6MB banwidth(rj-45) now i want segrigate the B.W to 2MB for one port and 2MB for second port and 2MB for third port.
is it possible can any body help in this
Thanks&Regards
srini
Kevin Dorrell Tue, 02/16/2010 - 07:41
I'm not sure I understand what you mean when you say "I have 6 Mb bandwidth".  I presume what you are getting at is that you have a 6 Mbps Internet connection via a router, and you want it to be shared fairly between three client PCs on your switch.
If it's the scenario I think it is, then you are receiving traffic from your Internet line at up to 6 Mbps.  Unfortunately, you have no control over the way the ISP sends you the traffic, so it is not possible to partition the line in the way you are suggesting.
I hope this helps.  If I have misunderstood the question, please could you expalin exactly what you want to achieve.
Kevin Dorrell
Luxembourg
