Routing question
Answered Question
Feb 16th, 2010
Simple question:
Will a 6509 still route traffic between connected vlans ( with interfaces and addresses assigned ) without the "ip routing" command in it's configuration?
Correct Answer by dario.didio about 7 years 1 month ago
IP Routing on a C6500 it is enabled by default, and it is also enabled on your C6500.
Overall Rating: 5 (1 ratings)
dario.didio Tue, 02/16/2010 - 05:28
  • Silver, 250 points or more
no this will not work.
When you disable routing you turn your C6500 into a bridge. In fact, you won't be able to have more than 1 L3 interface active.
HTH,
Dario
fdouble08 Tue, 02/16/2010 - 05:51
Reason I asked is that I have a 6509 with 7 vlans.  Each VLAN has a VLAN interface configured with an IP address assigned.  Traffic flows between VLANs with no problem.  The 6509 configuration does not include the "ip routing" command.  The following is from my 6509.  I trimmed unneccessary details to keep it small.
no aaa new-model
ip subnet-zero
ip domain-name **********
ip name-server **.**.**.**
mls flow ip destination
mls flow ipx destination
no mls acl tcam share-global
redundancy
mode sso
main-cpu
auto-sync running-config
auto-sync standard
spanning-tree mode pvst
diagnostic cns publish cisco.cns.device.diag_results
diagnostic cns subscribe cisco.cns.device.diag_commands
vlan internal allocation policy ascending
interface Vlan1
no ip address
shutdown
interface Vlan23
ip address 10.6.23.1 255.255.255.0
interface Vlan24
description Net_10.6.24.0/24-10.6.25.0/24
ip address 10.6.24.1 255.255.255.0
ip helper-address 10.6.24.93
no ip redirects
interface Vlan26
description Net_10.6.26.0/24
ip address 10.6.26.1 255.255.255.0
no ip redirects
interface Vlan27
description Net_10.6.27.0/24
ip address 10.6.27.1 255.255.255.0
no ip redirects
interface Vlan28
description Net_10.6.28.0/24
ip address 10.6.28.1 255.255.255.0
no ip redirects
interface Vlan29
ip address 10.6.29.1 255.255.255.0
no ip redirects
interface Vlan30
ip address 192.168.1.6 255.255.255.0
no ip redirects
interface Vlan40
ip address 10.10.4.1 255.255.252.0
no ip redirects
ip default-gateway 10.6.23.10
ip classless
ip route 0.0.0.0 0.0.0.0 10.6.23.10
ip route 10.0.46.0 255.255.255.0 10.6.23.5
no ip http server
tftp-server exit
dial-peer cor custom
end
dario.didio Tue, 02/16/2010 - 06:00
what do you get if you do a "show ip route"?
fdouble08 Tue, 02/16/2010 - 06:09
I see connected subnets and static routes for other subnets.
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 10.6.23.10 to network 0.0.0.0
     204.187.87.0/32 is subnetted, 1 subnets
S       204.187.87.33 [1/0] via 10.6.24.201
S       81.255.165.0/24 [1/0] via 10.6.23.10
S       81.255.170.41/32 [1/0] via 10.6.23.10
S       81.255.165.149/32 [1/0] via 10.6.23.10
     10.0.0.0/8 is variably subnetted, 30 subnets, 5 masks
S       10.26.16.0/20 [1/0] via 10.6.23.10
C       10.10.4.0/22 is directly connected, Vlan40
C       10.6.28.0/24 is directly connected, Vlan28
C       10.6.29.0/24 is directly connected, Vlan29
C       10.6.24.0/24 is directly connected, Vlan24
C       10.6.25.0/24 is directly connected, Vlan24
C       10.6.26.0/24 is directly connected, Vlan26
S       10.13.16.0/24 [1/0] via 10.6.23.10
C       10.6.27.0/24 is directly connected, Vlan27
C       10.6.23.0/24 is directly connected, Vlan23
S       10.1.16.0/20 [1/0] via 10.6.23.10
S       10.11.28.0/22 [1/0] via 10.6.23.10
S       10.6.46.0/24 [1/0] via 10.6.23.5
S       10.0.46.0/24 [1/0] via 10.6.23.5
S       10.65.0.0/16 [1/0] via 10.6.23.10
dario.didio Tue, 02/16/2010 - 06:15
Routing is enabled on your C6500. It is not in the config because it is enabled by default.
HTH,
Dario
fdouble08 Tue, 02/16/2010 - 07:08
I 'm not sure that routing is enabled by default.  The 6509 (w/msfc2) has MLS enabled.  With Multilayer switching enabled, it will "switch" layer 3 traffic.  Sort of like routing, only it appears to have some limitations.  But, I wouldn't expect it to allow me to create static routes without routing enabled.
Correct Answer
dario.didio Tue, 02/16/2010 - 07:25
Kevin Dorrell Tue, 02/16/2010 - 06:21
  • Green, 3000 points or more
Then it looks like ip routing is on by default.  I expect if you disabled it you would see no ip routing in the configuration, just like you do in a 4500.
Kevin Dorrell
Luxembourg
(Sorry Dario, crossed posting).
