ACE cli alias configuration
Feb 16th, 2010
is there any possibillity to cinfigure an cli alias on ACE ?
I am wondering that a "show alias" is possible:
ACE/Admin# show alias
CLI alias commands
ACE/Admin#
but the "normal" alias configuration doesn´t work, eg:
ACE/Admin(config)# cli alias name shint show interface
% invalid command detected at '^' marker.
I use the following SW:
Cisco Application Control Software (ACSW)
  loader:    Version 12.2[120]
  system:    Version A2(1.4a) [build 3.0(0)A2(1.4a) adbuild_12:09:43-2009/04/08_/auto/adbu-rel2/rel_a2_1_4_throttle/REL_3_0_0_A2_1_4A]
thx
dario.didio Tue, 02/16/2010 - 07:59
  • Silver, 250 points or more
I don't think that ACE supports alias commands.
Indeed, the show alias command works, but is a hidden commandP:
ACE/Admin# show  a
aaa          access-list  accounting   acl-merge    arp
CLI alias commands
ACE/Admin#
also in config mode, no command to configure aliases.
Looking in the command reference guide, no alias commands either.
So I don't think you can create alias commands (maybe in the future?)
I'm running A2(2.2)
HTH,
Dario
venkatkr Tue, 02/16/2010 - 09:09
  • Cisco Employee,
Though ACE software works on Linux kernel 2.4, it does not have all the linux functionality.There is no Alias command. Even if i login to the kernel mode, you will not have a alias command.
Venky
sthon-dbsys Wed, 02/17/2010 - 00:46
I know that "show alias" is a hidden command, so I thought there are also hodden config commands
Gilles Dufour Wed, 02/17/2010 - 00:57
  • Cisco Employee,
The CLI code is shared between different devices.
The 'show alias' is something we forgot to remove.
switch/Admin# show a?
However, as can be seen above, this is normally a hidden command.
There is no option to create alias on ACE
Gilles.
sthon-dbsys Wed, 02/17/2010 - 01:25
so it´s possible to misuse the script functionality to define some "alias" ?
... or can I start the "script procedure" only in configured probes ?
Gilles Dufour Wed, 02/17/2010 - 04:02
  • Cisco Employee,
there is no alias on ACE.  The command 'show alias' will be removed. (it is currently just hidden).
Script can only be called from probes.
Gilles.
