NAC clean access agent (CCA) question
Answered Question
Feb 16th, 2010
Iam going through OOB NAC deployment and i have a question about the CCA agent that will be persistent on the clients machines , if a client leave his work with the laptop that has the CCA agent and will use it in home or any different network , will the agent affect on the laptop access in any different network or not??? and why??
waiting your replies
MAM
Correct Answer by Faisal Sehbai about 7 years 2 months ago
Mohamed,
No difference in other networks. All you will see if you capture the traffic from that client is an UDP packet every 5 seconds. Since there will be no CAS in your other networks, that will be ignored and nothing else changes.
HTH,
Faisal
Overall Rating: 5 (1 ratings)
Correct Answer
Faisal Sehbai Tue, 02/16/2010 - 06:13
  • Gold, 750 points or more
Mohamed,
HTH,
Faisal
mohamed_makled Tue, 02/16/2010 - 06:33
Faisal
thanks for your reply.
please i have another question, if we integrate the NAC appliance with AD (enabling AD SSO feature) , will we need to do Mapping Rules on the CAM server or not ???
MAM
Faisal Sehbai Tue, 02/16/2010 - 06:40
Mohamed,
You don't have to do mapping rules. You can place all your users in a single default role which you define when you're defining the AD SSO provider. If you want to place them in different roles, based on certain attributes from AD, then you have to use mapping rules, so short answer, no.
HTH,
Faisal
