Can you terminate multiple IPSec tunnels between the same 2 peer endpoints?
Feb 16th, 2010
Hi All.
I am trying to terminate 2 different VRF aware IPSec tunnels between the same pair of public IP peering points.
This is in IOS (on Cisco 2811s).
Each tunnel will have a different VRF & different PSK, but everything else will be the same.
Is this possible?
Jon.
Federico Coto F... Tue, 02/16/2010 - 06:43
  • Green, 3000 points or more
What kind of configuration are you trying to accomplish?
Each vrf will have static routes or would you run an IGP?
Federico.
jjdennis1 Tue, 02/16/2010 - 06:48
Hello.
Normally we run OSPF, and then redistribute into MP-BGP at the PE.
But I can run static routing.
Does this have an impact?
Cheers,
Jon.
Federico Coto F... Tue, 02/16/2010 - 09:53
No impact, just asking because in plain IPsec tunnels you can't run dynamic routing protocols.
Have you tested yet the scenario?
Federico.
jjdennis1 Wed, 02/17/2010 - 08:41
Hey.
Well, these are IPSec tunnels dropped into a VRF (1 vrf per tunnel) so we can do whatever routing we like....
I haven't tested it yet, was just being lazy to see if I could get away without testing! ;-)
Will test 2mor on good old Dynagen and post the results.
Cheers.
