Ciscoworks backup configuration routers and switches
Feb 16th, 2010
Go to RME - Admin - Config Management
From there you can edit your Transport, Archive and Collection Settings.
Once this is done everything should be setup for config collection.
hey, i am trying to configure automaticaly backup.
i added the equipment to RME some is grey and some is good.
RME>Administration>Config Managment
there: Archive location : here some directory
then i go to, Collection Settings and make Periodic Polling and Periodic Collection . Enable and Schedule to 5 minutes from now
then i wait like 20 minutes no backup was created in the directory i choose, plus- does it backup everything in the rme ? or should i somewhere mark
the devices i wanna backup
thanks in advance
Ben
Joe Clarke Tue, 02/16/2010 - 13:24
I'm not quite clear on the problems you're seeing.  First, what version of RME are you using?  If you look at the archive directory on the file system, do you see ANY directories within it?  From the root dcma directory (e.g. C:\PROGRA~1\CSCOpx\files\rme\dcma) there should be baselinetemplates, configexport, devfiles, difffiles, newbaselinetemplates, shadow, and temp.  If these do not exists, then your archive directory is not writable by casuser.  You will need to fix this, then restart the ConfigMgmtServer daemon.
As for the devices which are not selectable in the UI, this could point to a package problem.  What type of devices are these exactly?  What are their sysObjectIDs?
commteam100 Tue, 02/16/2010 - 23:46
the folders exist in the location you mentioned
shadow > primary,vlan etc..
, but i'll check cause it might have been created with the admin account which opened an account for me.
as for your question i'm using version LMS2.6
theres the server itself users and theres the ciscoworks user under Security,
how do i ensure that the user can write over that folder?
as for the equipment(grey) i believe it's an snmp community mismatch, that is not important i'll fix that just after i manage to make a config backup.
the main question is, is Collection backup the entire equipment that exist in the rme devices or i have to pick.
Thank you very much for your time
Ben.
Joe Clarke Wed, 02/17/2010 - 08:21
If you right-click on the dcma directory (and all subdirectories), make sure the casusers group is listed there with full control access.
The grayed out devices in the device selector could be symtpomatic of a bad RME package repository.  In that case, you would need to open a service request with TAC to get a good package collection to recover the repository.
By default, RME will not do periodic config collection at all.  If you enable the system collection job, then RME will periodically collect configurations from ALL devices which are not conflicting or suspended.
commteam100 Thu, 02/18/2010 - 00:28
Thank you very much,
Currently, the problem is that the account is locked out too many wrong passwords
i'll update you if it's solved once
