ā02-16-2010 07:46 AM - edited ā03-15-2019 09:25 PM
Hello
My CCM is 6.1.2..and many CDR are error with code 42 (Temporary Failure)..
which can be caused the problem?(PSTN provider, local network (IPhone - GW, IPhone - CCM)..other..
thanks for your help
best regards
ā02-16-2010 09:06 AM
http://www.cisco.com/iam/unified/ipt611/Using_Call_Flows_to_Resolve_Call_Processing_Problems.htm
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
ā02-18-2010 12:58 AM
ok for set up PRI lines for a flex hunt sequence but how???
best regards
