g.726 codec support
Feb 16th, 2010
as far as I can tell UCM doesn't specifically support G.726 codecs in the Region configuration. If that codec is being used.... any advice to which setting in Region to use? I've checked various releases from 5.1 to 7.1... there doesn't seem to be any mention of g.726.
Rob Crawford
Tommer Catlin Tue, 02/16/2010 - 08:33
Check out Table 6-2
Looks to me that it is not supported.    Possibly, you may have to shoot the call through an h323 gateway and transcode it there to something say  G729.  Im not sure if that will work, but its worth a try.
Related Content
