Global Correlation Update Failures
Feb 16th, 2010
I've recently turned on Global Correlation but we've failed to update every 5 minutes.
PL-ASA-IPS# show stat global
Network Participation:
   Counters:
      Total Connection Attempts = 2
      Total Connection Failures = 0
      Connection Failures Since Last Success = 0
   Connection History:
      Connection Attempt on February 16 2010, at 14:28:38 UTC = Successful
      Connection Attempt on February 16 2010, at 14:19:06 UTC = Successful
Updates:
   Status Of Last Update Attempt = Failed
   Time Since Last Successful Update = never
   Counters:
      Update Failures Since Last Success = 4
      Total Update Attempts = 4
      Total Update Failures = 4
   Update Interval In Seconds = 300
   Update Server = update-manifests.ironport.com
   Update Server Address = 204.15.82.17
   Current Versions:
      config = 0
      drop = 0
      ip = 0
      rule = 0
Warnings:
I have a static NAT translation for the IPS, there are no proxy servers in our enviorment and it can ping outside as well as update-manifests.ironport.com (204.15.82.17). DNS is setup as well.
In the logs I see this entry:
16Feb2010 14:13:15.679 265.199 collaborationApp[491] rep/E A global correlation update failed: Failed download of ibrs/1.1/config/default/1236210407 : HTTP connection failed
I guess I'm at a loss for what else I can check. We have no problems sending the Network Participation data but we can't get any data. Any suggestions?
Cisco Intrusion Prevention System, Version 7.0(2)E3
Signature Definition:
    Signature Update    S469.0                   2010-02-11
    Virus Update        V1.4                     2007-03-02
OS Version:             2.4.30-IDS-smp-bigphys
barnes001 Tue, 02/16/2010 - 08:46
A few hours of searching led me to find out that the problem was being caused by an ASA/Websense combo. I has to tell the ASA to not apply filtering rules (HTTP and HTTPS) to the IPS' IP address.
Within minutes this fixed the issue.
walkerte Wed, 02/24/2010 - 18:18
Thanks Robert.  I had a similar configuration (ASA/Websense) and was getting the same errors.  The filter url except command fixed it in less than a minute.
JMC Nel Fri, 02/26/2010 - 12:41
I received "A global correlation update failed : Failed download of ibrs/1.1/drop/default/1267213766 : URI does not contain a valid IP address messages, like this one, in the category Reputation update failure
any ideas?
It has the default IP : 204.15.82.17
wps-asa-ips2# sh stat global
   Counters:
      Total Connection Attempts = 3167
      Total Connection Failures = 1
   Connection History:
      Connection Attempt on February 26 2010, at 20:24:42 UTC = Successful
      Connection Attempt on February 26 2010, at 20:14:39 UTC = Successful
      Connection Attempt on February 26 2010, at 20:04:34 UTC = Successful
      Connection Attempt on February 26 2010, at 19:54:35 UTC = Successful
      Connection Attempt on February 26 2010, at 19:44:40 UTC = Successful
Updates:
   Time Since Last Successful Update = 609 minutes
   Counters:
      Update Failures Since Last Success = 121
      Total Update Attempts = 4388
      Total Update Failures = 123
   Current Versions:
      config = 1236210407
      drop = 1267177755
      ip = 1267179307
      rule = 1267124528
walter baziuk Thu, 10/06/2011 - 04:19
I have the same issue, i have no ASA or websense product between this device and the iNet.
Does anyone have a fix or workaround?
I have an AIM-IPS running 7.0(6)E4 with Signature versuon S599.0. All updates to date have been manualy d/l to a local ftp server
the auto update "seems" to run but never gets any updates
This is what i see
# sh stat global
   Counters:
      Total Connection Attempts = 127
      Total Connection Failures = 127
      Connection Failures Since Last Success = 127
   Connection History:
      Connection Attempt on October 06 2011, at 10:46:32 UTC = Failed
      Connection Attempt on October 06 2011, at 09:24:32 UTC = Failed
      Connection Attempt on October 06 2011, at 08:03:04 UTC = Failed
      Connection Attempt on October 06 2011, at 07:59:52 UTC = Failed
      Connection Attempt on October 06 2011, at 06:36:57 UTC = Failed
Updates:
   Counters:
      Update Failures Since Last Success = 2702
      Total Update Attempts = 2702
      Total Update Failures = 2702
   Update Server Address = Unknown
   Current Versions:
      config = 0
      drop = 0
      ip = 0
      rule = 0
Warnings:
#sh ver
Application Partition:
Cisco Intrusion Prevention System, Version 7.0(6)E4
Host:
    Realm Keys          key1.0
    Signature Update    S599.0                 2011-09-29
OS Version:             2.6.14-Cavium-Octeon
Platform:               AIM-IPS-K9
Serial Number:          xxx
Licensed, expires:      31-Mar-2012 UTC
Sensor up-time is 9 days.
Using 54726656 out of 454148096 bytes of available memory (12% usage)
system is using 22.4M out of 80.0M bytes of available disk space (28% usage)
application-data is using 46.8M out of 213.0M bytes of available disk space (23% usage)
boot is using 54.4M out of 114.8M bytes of available disk space (50% usage)
application-log is using 61.8M out of 513.0M bytes of available disk space (12% usage)
MainApp            B-BEAU_2011_SEP_10_00_30_7_0_5_45   (Ipsbuild)   2011-09-10T00:32:09-0500   Running
AnalysisEngine     B-BEAU_2011_SEP_10_00_30_7_0_5_45   (Ipsbuild)   2011-09-10T00:32:09-0500   Running
CollaborationApp   B-BEAU_2011_SEP_10_00_30_7_0_5_45   (Ipsbuild)   2011-09-10T00:32:09-0500   Running
CLI                B-BEAU_2011_SEP_10_00_30_7_0_5_45   (Ipsbuild)   2011-09-10T00:32:09-0500
Upgrade History:
* IPS-AIM-K9-7.0-6-E4       17:39:07 UTC Sat Sep 10 2011
  IPS-sig-S599-req-E4.pkg   07:59:08 UTC Wed Oct 05 2011
Recovery Partition Version 1.1 - 7.0(6)E4
Host Certificate Valid from: 25-Sep-2011 to 25-Sep-2013
as seen above there is no ip address listed for "update-manifests.ironport.com"
NS lookup is able to resolve,
why can't the IPS?
I can i hard code the ip address?
>Non-authoritative answer:
>Address:  204.15.82.17
