CER 2.0-Unlocated Phones
Feb 16th, 2010
I have a switch whose phones cannot be tracked. I did SNMP walk and got following output.
admin:utils snmp walk 2c CXXXXXXXXX 13X.XX.XX.XX 1.2.6.1.4.1.9.1.614
> This command may temporarily impact CPU performance.
> Continue (y/n)?y
> iso.2.6.1.4.1.9.1.614 = No Such Object available on this agent at this
> OID
> Walked further up the tree. results below...
> admin:utils snmp walk 2c CXXXXXXXXX 13X.XX.XX.XX 1.2.6.1.4.1.9.1 This
> Continue (y/n)?y
> iso.2.6.1.4.1.9.1 = No Such Object available on this agent at this OID
> admin:utils snmp walk 2c CXXXXXXXXX 13X.XX.XX.XX 1.2.6.1.4.1.9 This
> Continue (y/n)?y
> iso.2.6.1.4.1.9 = No Such Object available on this agent at this OID
> admin:utils snmp walk 2c CXXXXXXXXX 13X.XX.XX.XX 1.2.6.1.4.1 This
> Continue (y/n)?y
> iso.2.6.1.4.1 = No Such Object available on this agent at this OID
> admin:utils snmp walk 2c CXXXXXXXXX 13X.XX.XX.XX 1.2.6.1.4 This
> Continue (y/n)?y
> iso.2.6.1.4 = No Such Object available on this agent at this OID
> admin:utils snmp walk 2cCXXXXXXXXX 13X.XX.XX.XX 1.2.6.1 This command
> Continue (y/n)?y
> iso.2.6.1 = No Such Object available on this agent at this OID
> admin:utils snmp walk 2c CXXXXXXXXX 13X.XX.XX.XX 1.2.6 This command
> Continue (y/n)?y
> iso.2.6 = No Such Object available on this agent at this OID
> admin:utils snmp walk 2c CXXXXXXXX 13X.XX.XX.XX 1.2 This command may
> Continue (y/n)?y
> iso.2.840.10006.300.43.1.2.1.1.2.10101 = INTEGER: 32768
> iso.2.840.10006.300.43.1.2.1.1.2.10102 = INTEGER: 32768
> iso.2.840.10006.300.43.1.2.1.1.2.10103 = INTEGER: 32768
Phone tracker logs show
668369: Feb 08 11:13:33.897 PST %CER-CER_PHONETRACKINGENGINE-7-DEBUG:CER Message Receiver T:DiscoveryDetails setSelectiveDiscover UnreachableSwitches: [134.164.19.250]
Can you please tell me what the issue is. This is 3560 switch.
Tommer Catlin Tue, 02/16/2010 - 09:01
  • Green, 3000 points or more
Hi there!
Can you use a simple SNMP application to querry the switch?  For example, can Solar Winds querry the switch and come back with the basic switch info?
