02-16-2010 11:26 AM
I have a 28xx IOS router with 8 fxo's and 2 x 16 channel pvdm2's. I want to use dsp resources for hardware MTP but when I try to configure it I only have 0 as an allowed entry.
(config-dspfarm-profile)#maximum sessions hardware ?
<0-0> Number of sessions assigned to this profile
I thought I would have at least 16 available to assign. Any advice?
02-16-2010 01:50 PM
Do a "show voice dsp" to see where the DSP resources are allocated. Also, be sure you have DSP service enabled for the voice card such as:
voice-card 1
dsp services dspfarm
Hope this helps.
Brandon
03-01-2010 03:34 PM
You can also try this command:
show call resource voice stats
And you have 0 as it was mentioned in the answer above: "dsp services dspfarm" command was not entered under
voice-card 1
