2900 ISR compatibility CUCM 6.X
Answered Question
Feb 16th, 2010
Does anyone have a doc on comptability matrix for the 2900 routers?  We are starting to order these for our remote sites, but we are sitting at 6.1.3.
Correct Answer by Brandon Buffin about 7 years 1 month ago
Looks a minimum of 6.1.5 is required for the 2900 series.
http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet0900aecd8057f2e0.pdf
Hope this helps.
Brandon
Overall Rating: 5 (1 ratings)
CHRIS CHARLEBOIS Tue, 02/16/2010 - 13:01
  • Silver, 250 points or more
If you are looking to run MGCP on the 2900 ISR, I think you may be out of luck.  My 6.1.4 doesn' t recoginize a 2900 series type for MGCP.  It will probably be available in a patch sooner or later, but I don't know when.
However, if you want to run H.323, you should be fine.  CUCM doesn't care what hardware is running the gateway if it's using the H.323 protocol.
Chris
hauchinango Tue, 02/16/2010 - 13:08
Thanks, yeah, looks like 6.1.5 is going to be my route.  It was just released a week ago or so, so I will be
holding off for a bit.
Thanks again
