What is the difference on redirecting a URL and a server on ACE
Feb 16th, 2010
users come in on mysite.com--------different external IP and VIP
they get redirected to www.mysite.com---different external IP and VIP
looks like they are currently being redirected on the IIS server
how would i redirect them to a new url on the same server with a different external IP an VIP on the Loadbalancer?
the webhost redirection ?
would that involve the url redirect commant too?
venkatkr Tue, 02/16/2010 - 16:37
  • Cisco Employee,
The ACE can do redirect using the webhost-relocation command. So the client comes back and hits the ACE again on the redirected rule
so in short
client hits www.mysite1.com
DNS resolves it ot 2.2.2.2 VIP
ACE gets it and redirects it to http://www.mysite2.com
DNS resolves to 3.3.3.3 vip
ACE terminates that traffic.
Is that what you were looking for ?
Venky
nygenxny123 Tue, 02/16/2010 - 17:42
hmm
My concern is that the server team wants to redirect the urls to the same server ....
so the rserver for xample
is
rserver host serverwebsite
ip address 1.1.1.1
inservice
is associated in 2 server farms
servfarm host website1
rserver serverwebsite 80
inservice
and server host website2
inservice
so how would is it possible to redirect a url to another url on the same server with the same server ip
after a SSL handshake?
Gilles Dufour Wed, 02/17/2010 - 00:27
  • Cisco Employee,
ACE can intercept the request from the client before it is sent to the rserver.
So, you can catch whatever URL you want and without contacting the rserver send a redirect to a new vip.
The next request from the client to the new vip can then be loadbalanced to an rserver.
Does not matter if the rserver is being used in multiple serverfarm.
If you have problem to realise such a config, send us EXACTLY what you would like to do and your current config and we can guide you.
Gilles.
nygenxny123 Thu, 02/18/2010 - 08:41
bascially
we have 2 external site...mysite.com and www.mysite.com.....both have their own vips on the loadbalancer
both go to the same server......the IIS on the server recirects so that the request without the "www" gets
redirected to www.
we are settingup a new site...and we would like the old site to get redirected to the newsite
www.mynewsite.com.........
here is a sample of the new site
we would like the 2 previous sites to be redirected to www.mynewsite.com
class-map match-all MYNEWSITE-WEB-VIP
  2 match virtual-address 172.20.100.115 tcp eq https
class-map match-all MYNEWSITE-WEB-redirect
  2 match virtual-address 172.20.100.115 tcp eq www
class-map type http loadbalance match-any HOSTHEADER
  2 match http header Host header-value "mynewsite.com"
  3 match http header Host header-value "mynewsite.net"
  4 match http header Host header-value "www.mynewsite.net"
rserver redirect MYNEWSITE-WEB-redir
  webhost-redirection https://www.mynewsite.com/%p
  inservice
serverfarm redirect MYNEWSITE-WEB-redir
  rserver MYNEWSITE-WEB-redir
    inservice
policy-map type loadbalance first-match MYNEWSITE-POLICY
  class HOSTHEADER
    serverfarm MYNEWSITE-WEB-redir
  class class-default
    sticky-serverfarm MYNEWSITE-WEB_cookie
    action urlrewrite
policy-map type loadbalance first-match MYNEWSITE-WEB-redir
  class class-default
policy-map multi-match VIPs
  class MYNEWSITE-WEB-VIP
    loadbalance vip inservice
    loadbalance policy MYNEWSITE-POLICY
    loadbalance vip icmp-reply active
    appl-parameter http advanced-options HTTP_PARAMETER_MAP
    ssl-proxy server MYNEWSITE-WEB-PROXY
  class MYNEWSITE-WEB-redirect
    loadbalance policy MYNEWSITE-WEB-redir
Gilles Dufour Thu, 02/18/2010 - 23:27
  • Cisco Employee,
Your config looks good.
what is the part not working ?
If the sites use different ip addresses, you will need new class-map to catch this traffic and use your redirect policy to redirect them to the correct site.
Gilles.
nygenxny123 Fri, 02/19/2010 - 14:10
well it appears that the IIS itself was doing the redirect...
so we now i am having this problem
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
rserver redirect MYNEWSITE-redir
  webhost-redirection https://www.myoldsite.com/%p
  inservice
I get redirected fine…..up to the first “forward slash”
Server level (works)
https://www.mynewsite.com-------gets redirected to https:www.myoldsite.net/----good
Application level (works)
https://www.mynewsite.com/ARR---gets redirected to https://myoldsite.net/ARR----good
File level – doesn’t work:
https://www.mynewsite.com/ARR/LoginPKI.aspx---but this stays the same and doesn’t get redirected…..
do I need to add another %p on the rserver redirect MYNEWSITE-WEB-redir
