02-16-2010 02:42 PM
DMVPN configuration.
Devices from Hub LAN to Spoke LAN ping times 60ms.
Devices from Spoke1 LAN to Spoke2 LAN ping times 110ms to 1000ms.
When I ping the mGRE addresses of the routers. I can ping at 30-45ms unless I ping the routers own IP address, then it responds at a 90ms response. Meaning:
Spoke1 to Spoke2 = 40ms
Spoke1 to Hub = 35ms
Spoke2 to Hub = 35ms
Spoke1 to self = 90ms
Spoke2 to self = 90ms
HUB config:
crypto keyring Cisco
pre-shared-key address 0.0.0.0 0.0.0.0 key KeyA
crypto ipsec transform-set ESP-3DES-SHA13 esp-3des esp-sha-hmac
mode transport
crypto isakmp profile Cisco
keyring Cisco
match identity address 0.0.0.0
crypto ipsec profile CISCO
set transform-set ESP-3DES-SHA13
set isakmp-profile Cisco
interface Tunnel0
description HUB
bandwidth 4000
ip address 10.151.151.1 255.255.255.248
no ip redirects
ip mtu 1416
ip nhrp authentication Cisco
ip nhrp map multicast dynamic
ip nhrp network-id 100000
ip nhrp holdtime 360
ip tcp adjust-mss 1360
no ip split-horizon eigrp 1
delay 1000
tunnel source GigabitEthernet0/0
tunnel mode gre multipoint
tunnel key 100000
tunnel protection ipsec profile CISCO
interface GigabitEthernet0/0
description HUB
bandwidth inherit
ip address A.A.A.A 255.255.255.252
ip verify unicast reverse-path
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed 100
media-type rj45
negotiation auto
router eigrp 1
network 10.3.3.0 0.0.0.255
network 10.150.150.0 0.0.0.255
network 10.151.151.0 0.0.0.7
network 192.168.27.0
no auto-summary
SPOKE1 config:
crypto isakmp key KeyA address 0.0.0.0 0.0.0.0
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
mode transport
interface Tunnel0
description SPOKE1
bandwidth 4000
ip address 10.151.151.2 255.255.255.248
no ip redirects
ip mtu 1416
no ip next-hop-self eigrp 1
ip nhrp map 10.151.151.1 A.A.A.A
ip nhrp map multicast A.A.A.A
ip nhrp nhs 10.151.151.1
delay 1000
tunnel source GigabitEthernet0/1
tunnel key 100000
interface GigabitEthernet0/1
description SPOKE1
ip address B.B.B.B 255.255.255.252
ip nat outside
duplex auto
speed auto
media-type rj45
router eigrp 1
network 10.148.27.0 0.0.0.255
network 10.148.148.0 0.0.0.255
no auto-summary
SPOKE2 config:
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
mode transport
interface Tunnel0
description SPOKE2
bandwidth 4000
ip address 10.151.151.3 255.255.255.248
no ip redirects
ip mtu 1416
ip nhrp authentication Rentsys
delay 1000
tunnel key 100000
description SPOKE2
ip address C.C.C.C 255.255.255.252
ip nat outside
ip route-cache flow
duplex full
speed 100
media-type rj45
router eigrp 1
passive-interface default
no passive-interface Tunnel0
network 10.149.149.0 0.0.0.255
no auto-summary
I did a trace on a device on Spoke network 1 to a device on Spoke network 2. I noticed that the trace route goes through the mGRE and hops to the HUB GRE tunnel address. Is this the correct reflex for this configuration?
1 10.148.148.1 0 msec 0 msec 0 msec (internal address of Spoke 1 router)
2 10.151.151.1 50 msec 50 msec 51 msec (GRE "outside" address of HUB)
3 10.151.151.3 109 msec 109 msec 109 msec (GRE "outside" address of Spoke 2 router)
4 10.149.149.254 109 msec * 109 msec (Device on Spoke 2 router)
Solved! Go to Solution.
02-16-2010 04:24 PM
Spoke1 should send out a NHRP request to HUB, and HUB reply with spoke2's mapping; after that spoke should build a spoke to spoke tunnel, and traffic from spoke to spoke should use that tunnel.
Do you have "no ip next-hop-self eigrp 1" configured under your hub tunnel interface?
If your IOS is 12.4(6)T or higher, you can consider use dmvpn phase 3.
HTH,
Lei Tian
02-16-2010 04:24 PM
HTH,
Lei Tian
02-17-2010 07:58 AM
Lei,
That was the issue. I looked through that config about a thousand times and just missed that command.
Thanks for you help!
Jason
