CER backup and restore
Answered Question
Feb 16th, 2010
we have a CER in the lab, I start configuring the CER. I need to backup configuration and restore to a new CER with the same version. when I backup from CER, it creates 8 tar files. which tar file is related to the configuration?
thanks for any suggestion
Alex
Correct Answer by htluo about 7 years 2 months ago
You'll need all of them.  They are for different components (such as database, platform, etc.)
Actually, the backup will generate an XML file.  The same XML file will be used for restore.
Michael
http://htluo.blogspot.com
Overall Rating: 5 (1 ratings)
Correct Answer
htluo Tue, 02/16/2010 - 15:28
  • Red, 2250 points or more
Michael
