/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
can ASA supports WCCP between the interfaces INSIDE to DMZ?
I i have proxy server in DMZ zone and i want to enable the WCCP on ASA will it work?
If WCCP is not supported between interfaces then is there any work around to redirect the internet traffic from inside to dmz on proxy server using ASA.
Panos Kampanakis Wed, 02/17/2010 - 09:09
The wccp engine needs to be behind the same interface that the redirected users will be.
Also the wccp engine needs to be able to talk directly to the users.
The only workaround would be to make sure routing put the wccp engine in the same interface as the users and the users can talk to the engine directly.
I hope it helps.
