ACS 4.1.3 configure csmon sender mail address
Answered Question
Feb 17th, 2010
Correct Answer by Jagdeep Gambhir about 7 years 2 months ago
Rocco,
Enhancement request already filed on this issue,
CSCsv80198            Bug Details
Enh: User configurable Mail Sender for CSMon   This is an enhancement request.Adding the ability for the end user to be able to configure the from address for CSMon Alerts Emails.
There is no ETA available.
~JG
Do rate helpful posts
Overall Rating: 5 (2 ratings)
Correct Answer
Jagdeep Gambhir Wed, 02/17/2010 - 10:32
  • Red, 2250 points or more
Rocco,
~JG
rocco.scholz Wed, 02/17/2010 - 23:28
Hi JG,
thanks for your fast reply. I will try to explain the problem we have,
our customer has ACS 4.1.3.12 and uses csmon to send email notifications. All worked well until he changed the recipient mail address to a new one.
Since this minor change the csmon nnotifications will be blocked by the mail server because of an unsupported format.
normally he received the mails with [email protected] where auth5 is the name of the ACS after changing the recipient mails will arrive at the mailserver with csmon@134.247.222.12 where 134.247.222.12 is the ip address of the mailserver. It is crazy, isn't it?
DNS resolution still works well on ACS(also Reverse Lookup). Have you got an idea?
Thank in advance.
Rocco
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Normale Tabelle"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Jagdeep Gambhir Fri, 02/19/2010 - 06:08
Hi Roco,
In latest versions (4.x), the From field or the Mailsender is derived from the SMTP server name configured on the service management page.( i.e. mail comes from csmon_alert@ (SMTP mail server configured) .And this is not configurable.
When you upgrade from 3.3 to 4.x versions, you will see that the Mailsender configuration is retained as the server hostname ( csmon_alert@ . ) So restoring the backup from the old server to new server causes the mailsender name to be wrong.
To return to the defaut 4.x behaviour (sender name as the SMTP server configured ), we need to just submit the "ACS Service management" page once.
So that is why after making a change, it started using smpt server name (default behaviour)
~JG
rocco.scholz Sun, 02/21/2010 - 23:06
thanks for your fast reply and for this qualified explanation of the problem.
cheers,
Rocco
