standby cisco ACE loadbalancer issues (network connectivity)
nvkiran_k
Hi ALL,
            We are having issues with the secondary (standby) load balancer ACE module on a 6500 switch. We see that the loadblanacer is not able to get onto the network which leads to problem with fault tolerance as well. Following is the ft status found on the load balancer for one of the contexts (this is the same pattern seen on all the contexts).
switch/Admin# sh ft group status
FT Group                     : 1
Configured Status            : in-service
Maintenance mode             : MAINT_MODE_OFF
My State                     : FSM_FT_STATE_ACTIVE
Peer State                   : FSM_FT_STATE_UNKNOWN
Peer Id                      : 1
No. of Contexts              : 1
Sh arp on all the contexts shows the gateway/rserver to be unreachable. Please find the screenshot below for one of the contexts (the same pattern is seen on the LB for all other contexts)
switch/1_Context# sh arp
Context CSD_Context
IP ADDRESS      MAC-ADDRESS        Interface  Type      Encap  NextArp(s) Status
172.21.128.97   00.00.00.00.00.00  vlan942   GATEWAY    -                   dn
172.21.128.103  00.0b.fc.fe.1b.09  vlan942   ALIAS      LOCAL     _         up
172.21.128.105  00.12.43.dc.93.23  vlan942   INTERFACE  LOCAL     _         up
7.0.0.4         00.0b.fc.fe.1b.09  vlan943   NAT        LOCAL     _         up
- 7.0.0.6
172.21.147.196  00.0b.fc.fe.1b.09  vlan943   ALIAS      LOCAL     _         up
172.21.147.198  00.12.43.dc.93.24  vlan943   INTERFACE  LOCAL     _         up
172.21.147.200  00.00.00.00.00.00  vlan943   RSERVER    -       * 3 req     dn
172.21.147.202  00.00.00.00.00.00  vlan943   RSERVER    -       * 2 req     dn
172.21.147.204  00.00.00.00.00.00  vlan943   RSERVER    -                   dn
172.21.147.206  00.00.00.00.00.00  vlan943   RSERVER    -                   dn
172.21.147.208  00.00.00.00.00.00  vlan943   RSERVER    -       * 3 req     dn
172.21.147.210  00.00.00.00.00.00  vlan943   RSERVER    -       * 2 req     dn
172.21.147.212  00.00.00.00.00.00  vlan943   RSERVER    -       * 1 req     dn
172.21.147.214  00.00.00.00.00.00  vlan943   RSERVER    -       * 1 req     dn
172.21.147.216  00.00.00.00.00.00  vlan943   RSERVER    -       * 3 req     dn
7.0.0.1         00.0b.fc.fe.1b.09  vlan943   NAT        LOCAL     _         up
- 7.0.0.3
The problem is that we see the problem only on the secondary loadbalancer. primary is just running file
also i can see some traffic denial in admin context for resource usage
switch/Admin# sh resource usage
                                                     Allocation
        Resource         Current       Peak        Min        Max       Denied
Context: Admin
  conc-connections              9          9     160000    6560000          0
  mgmt-connections              0         46       2000      82000          0
  proxy-connections             0          4      20972     859830          0
  xlates                        0          0      20972     859830          0
  bandwidth                     0   17715713   10000000  535000000    5799749
    throughput                  0   17710993   10000000  410000000    5799749
    mgmt-traffic rate           0       4720          0  125000000          0
  connection rate               0         43      20000     820000          0
  ssl-connections rate          0          0        100       4100          0
  mac-miss rate                 0          1         40       1640          0
  inspect-conn rate             0          0        120       4920          0
  acl-memory                56336      56336    1570072   64460552          6
  sticky                        0          0      83886          0          0
  regexp                        0          0      20972     859832          0
  syslog buffer             82944      82944      82944    3447808          0
  syslog rate                   0         44       2000      82000         25
Context: INTEGRATION_Context
  conc-connections              0       3934     160000          0          0
  mgmt-connections              0         98       2000          0          0
  proxy-connections             0         33      20972          0          0
  xlates                        0          0      20972          0          0
  bandwidth                     0   10019910   10000000  125000000      40857
    throughput                  0   10000000   10000000          0      40857
    mgmt-traffic rate           0      19910          0  125000000          0
  connection rate               0         49      20000          0          0
  ssl-connections rate          0          0        100          0          0
  mac-miss rate                 0         32         40          0          0
  inspect-conn rate             0         58        120          0          0
  acl-memory                11920      11920    1570072          0          0
  sticky                        0          1      83886          0          0
  regexp                        0          0      20972          0          0
  syslog buffer                 0      82944      82944    3447808          0
  syslog rate                   0        312       2000          0          0
these above 2 contexts are the only one which has bandwidth resource usage exceeding the limit. but i somehow am not sure if this is the issue. as there is just no traffic on the secondary .. then how can the bandwidth reach the threshold? can anyone throw some light on the below issue?
thanks and regards
kiran
dario.didio
Level 4
Level 4
Can you confirm that the VLANs are passed to the ACE module using the "svclc ...." commands on the supervisor?
You should be able to see them when doing a show vlan in the Admin context.
Can you also confirm that the FT VLAN spans between the two Catalyst chassis?
HTH,
Dario
vlan on Standby_ACE switch
svclc multiple-vlan-interfaces
svclc module 1 vlan-group 1,4,12,13,
svclc vlan-group 1  968
svclc vlan-group 12  132
svclc vlan-group 13  367-372,374,375,379,380,538,805,807,808,818,913,915
svclc vlan-group 13  917-920,922-924,933,934,937,938,942-949,972,976-979,983
svclc vlan-group 13  984
ip subnet-zero
no ip source-route
vlans on standby ACE
switch/Admin# sh vlans
Vlans configured on SUP for this module
vlan132  vlan360  vlan367-375  vlan379-380  vlan538  vlan805  vlan807-808  vlan818  vlan913  vlan91
5  vlan917-920  vlan922-924  vlan930  vlan933-934  vlan937-938  vlan942-949  vlan968  vlan971-972  v
lan976-979  vlan983-984
switch/Admin#
Active_LB_host_switch is the switch hosting the  active ACE thats connected on ten7/4 and 8/4 which is bundeled and made into
port-channel (po72)
CDP neighbor hosting the active ACE
                 Ten 7/4           148          R S I     WS-C6513  Ten 7/4
                 Ten 8/4           156          R S I     WS-C6513  Ten 8/4
Po72 allows all the vlans which is the configured for ACE modules.
Port                Vlans allowed on trunk
Po72                132,140,181,359-383,538,668,702,805-808,815-816,818-820,836,907,909-920,922-925,
            929-935,937-949,967-973,976-984,987,3212
vlan 968 is the FT vlan and the same hass been allowed on the trunk port.
everything looks good to me but still not sure why isnt the ACE module not coming to the network. it was working fine
a few months back but all of a sudden it lost the network connectivity. i am not even able to ping the physical ip of the
ACE module.
thanks and regards
kiran
seanbowles
I had a problem with the FT blades (Active/Standby) across data centers, where the FT configuration was correct, however they did not synch correctly.  I had FT flapping, even without the preempt enabled.  Basically, after I checked the licensing, re-installed the licenses on both modules and upgraded to the latest code, my FT problems went away.  Viola!  HTH, -S
