Unable to access CUE 7.1.4 GUI
Feb 17th, 2010
I have a 2811 with an AIM-CUE 7.1.4 and after the initial configuration through CLI I can not access to the GUI.
When I try to access to http://ip-cue/Web, it redirects me to http://ip-cue/Web/Common/Login.do and I can see the Cisco favicon and the status bar says "Ready" but there is not anything on the page.
I traced this error with "trace webinterface all" in CUE and this is the output I got:
3781 02/17 11:52:04.466 webInterface controller "Requested URI " Enter /Web/Common/HomePage.do
3781 02/17 11:52:04.466 webInterface sysdb "Getting sysdb attribute" /sw/apps/tomcat/config/httpsKeyLabel
3781 02/17 11:52:04.468 webInterface sysdb "Value"
3781 02/17 11:52:04.468 webInterface controller "Forwarding to " Exit /Common/Login.do
3781 02/17 11:52:04.469 webInterface controller "Requested URI " Enter /Web/Common/Login.do
3781 02/17 11:52:04.469 webInterface sysdb "Getting sysdb attribute" /sw/apps/tomcat/config/httpsKeyLabel
3781 02/17 11:52:04.470 webInterface sysdb "Value"
3781 02/17 11:52:04.470 webInterface controller "Requested URI " Center /Web/Common/Login.do
3781 02/17 11:52:04.471 webInterface sysdb "Getting sysdb attribute" /sw/local/users/PasswordPolicy/minLength
3781 02/17 11:52:04.472 webInterface sysdb "Value" 3
3781 02/17 11:52:04.473 webInterface sysdb "Getting sysdb attribute" /sw/apps/monitor//ctrl/offline
3781 02/17 11:52:04.474 webInterface sysdb "Value" 0
3781 02/17 11:52:04.474 webInterface sysdb "Getting sysdb attribute" /sw/apps/gui/runtime/applicationMode
3781 02/17 11:52:04.475 webInterface sysdb "Value"
3781 02/17 11:52:04.478 webInterface sysdb "Getting sysdb attribute" /sw/limits/global/applicationMode
3781 02/17 11:52:04.479 webInterface sysdb "Value" CCM
Anybody has faced a similar issue? I have another CUE version 3.2.2 on the same network and I can access to its GUI.
I attach the CUE and GW configurations.
Thanks!
Isaac.
