2950 switch - management ip
Answered Question
Feb 17th, 2010
I have setup the switch below via the console port, with 3 vlans on it, port 1 is a trunk, port 2-4 vlan 2, port 5-11 vlan 3, port 12 vlan 1.
I have setup up an ip address on interface vlan1 for the switch so that i can manage it. However if i connect a computer up to port 12 with the ip 10.208.0.1, then i can not access the management ip of 10.208.0.253. Do you have any ideas or is there a better way to give the switch a management ip on vlan 1.
config below.
Mark
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
enable secret 5 $1$xxxxx
username xxx password 0 xxxxxxx
ip subnet-zero
no ip domain-lookup
interface FastEthernet0/1
switchport trunk allowed vlan 1-3,1002-1005
switchport mode trunk
no ip address
interface FastEthernet0/2
switchport access vlan 2
no ip address
interface FastEthernet0/3
no ip address
interface FastEthernet0/4
no ip address
interface FastEthernet0/5
switchport access vlan 3
no ip address
interface FastEthernet0/6
no ip address
interface FastEthernet0/7
no ip address
interface FastEthernet0/8
no ip address
interface FastEthernet0/9
no ip address
interface FastEthernet0/10
no ip address
interface FastEthernet0/11
no ip address
interface FastEthernet0/12
no ip address
interface Vlan1
ip address 192.168.0.253 255.255.255.0
no ip route-cache
ip http server
line con 0
password thermeon
logging synchronous
line vty 0 4
login local
transport input telnet
line vty 5 15
login
end
Correct Answer by spremkumar about 6 years 11 months ago
You have configured 192.168.0.253 under your vlan1 interface, change that to your new ip scheme and check.
regds
Overall Rating: 5 (1 ratings)
Correct Answer
spremkumar Wed, 02/17/2010 - 07:45
regds
pixie79UK Wed, 02/17/2010 - 07:51
thanks, i had not realised that i entered the ip address in with the wrong ip
