02-17-2010 08:08 AM - edited 03-06-2019 09:44 AM
To implement the HSRP on 2 different networks and connect them to each others (for example network A and network B) with cisco switch 3560, how many switches are required?
Network A = 2 switches
Network B = 2 switches
or
Network A = 1 switch
Network B = 1 switch
Your help is much appreciated. Thanks.
02-17-2010 08:12 AM
or
To implement HSRP you would need at least 2 switches per subnet for it to make any sense. But you could use the same 2 switches for both network A and network B.
Jon
02-17-2010 09:31 AM
or
To implement HSRP you will need at least two switches and for running HSRP in two different subnet you can also achive with the same two switches by creating vlans and apply HSRP to those vlans.
Hope to help
If helpful do rate the post
Ganesh.H
