t1 cas caller id mdmf format
Answered Question
Feb 17th, 2010
Customer ordered a pstn circuit and ended up with a T1 CAS rather than PRI. So naturally the age old how does caller id work.
My understanding is that you need fgd ports to make this work, but I want to be sure of my ground. the carrier is saying they are delivering the number via mdmf format. Isn't that the old delimiter *ani*dnis* kind of thing?  My understanding is that ISR routers don't support this. Is that true?
thx again
Correct Answer by paolo bevilacqua about 7 years 2 months ago
Contact at the address present in my profile, please.
Correct. Sometime CAS circuits require a little timing adjustments.
Overall Rating: 5 (1 ratings)
whanson Wed, 02/17/2010 - 11:20
you are something. do you code the ds0-group and   e&m-wink-start  dtmf dnis?    Or is it done some other way
Bill
Correct Answer
paolo bevilacqua Wed, 02/17/2010 - 11:24
  • Hall of Fame,
    Founding Member
whanson Wed, 02/17/2010 - 11:31
okay, out of curiousity what would this script cost?
Correct Answer
paolo bevilacqua Wed, 02/17/2010 - 11:36
  • Hall of Fame,
    Founding Member
whanson Wed, 02/17/2010 - 12:05
thanks for all your help. Not sure how you let folks know except to click correct answer. I liked the old way better. If there is a rating system let em know. Thanks again
paolo bevilacqua Wed, 02/17/2010 - 10:18
  • Hall of Fame,
    Founding Member
Ask explicitely... Different people use different terms.
I have a script for *ani*dnis* plus name association. Some custoemr were happy with it until finally switched to PRI.
