Configuring access with Certificate or AAA on ASA5520
Feb 17th, 2010
Hi there!
I'm trying to configure a Cisco ASA 5520 to authenticate SSL VPN users via either certificate or local AAA, ie, normally the user will connect with a certificate but from time to time, users may forget their card at work and I would like to offer them an alternative way of logging via user and password.
When I try to configure this:
I access to Remote Access VPN > Clientless SSL VPN Access > Connection Profiles > Basic
The device gives 3 authentication methods: AAA, certificate and both
The question is: Is there anyway of configuring certificate as the main authentication method and AAA as a backup method?
Thank you in advance
Ivan Martinon Thu, 02/18/2010 - 10:32
This will be possible in the future, currently the following bug will be affecting you
CSCef16611
WebVPN configured for both AAA and Certificate Auth only does certs
Symptom:
If WebVPN authentication is configured for both AAA and certificates in the tunnel-group, only certificate authentication takes place.
Conditions:
WebVPN authentication is configured for both AAA and certificates.
Workaround:
None availble. Currently WebVPN auhenticaiton is by AAA or Certificates, and not both simultaneously.
It will always take CERT if both are configured.
Related Content
