VPN Client 4.8.2 assistance please
Feb 17th, 2010
We have a VPN 3000 series concentrator and was using 4.8.1 client.  We where told to upgrade to 4.8.2 and so we did.  On local tests with the ASR it will connect.  When it is taken home, it will not establish any connection.  It gives us this error; /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
"Secure VPN Connection
terminated locally by the Client. Reason 412:The remote peer is no longer
responding"
When we switch back to 4.8.1 everything works fine.  We are using Windows XP as the computer OS.
Thank you,
Ron
Related Content
