Callmanager 5.x , 66 % memory Utilization
Feb 17th, 2010
Hi All ,
i am using  callmanager 5.x , memory utilization reaching upto 66 % .
is that normal for publisher server ?
what could be the reasons to make memory Utilization High .
we have 2 servers  MCS 7835( PUB & SUB)
aslam.bajwa Thu, 02/18/2010 - 04:06
Hi ,
i am sorry , i couldnt not understand .
you want me visit below link and open case ??
please advise .
markbatts Thu, 02/18/2010 - 05:25
Hi ,
What java is saying is that you don't need to worry.I have seen callmanager 5.x with very high mem utilisation and be quite happy.There are quite a few bugs with memory leaks in the older versions of 5.x but unless you have a problem i would ignore it.
Jaime Valencia Thu, 02/18/2010 - 06:14
Indeed, if you have ever worked with Linux platforms you'll know this is the default behavior. They always grab as much memory as they can to avoid using the HDD.
Aslam: Matt already told you this, but if you need help, you need to open a case. DO NOT reach our mailers directly for non-program related questions.
If you don't have access to PDI then reach TAC or your SE.
If this helps, please rate
