dvaggalis Wed, 02/17/2010 - 11:13
checked the Datasheet, but it doesn't give performance spec's.  I know I can physically install (2) AIM-ATM modules and (8) T1's, not sure what effect on this would have on the router.
Giuseppe Larosa Wed, 02/17/2010 - 13:54
it  is reasonable to think 4-6 T1 in ATM IMA is what you can get from it
consider to use a single NM ATM T3 if possible.
Hope to help
Giuseppe
