IPSEC or AnyConnect for MAC OSX. How to display network parameters from client
Answered Question
Feb 17th, 2010
With Windows using either AnyConnect or the Cisco IPSEC client on ASA, I can type IPCONFIG /ALL and see the associated network parameters - IP addresses, DNS, domain search order, etc under the Cisco VPN adapter. This is very helpful when troubleshooting connectivity issues.
I cannot find similar commands (GUI or Command Line) for MAC OSX. Networksetup doesn't seem to see any VPN adapter at all.
Can anyone with better MAC knowledge than I provide some assistance? Thanks.
Correct Answer by Brandon Svec about 7 years 3 days ago
I use both OS X built in Cisco IPSEC and AnyConnect. I can't speak to
Cisco's IPSEC client.
So with AnyConnect running I can click on AC menu icon and see some stats
like IP address, etc.
ifconfig returns:
utun0: flags=8091 mtu 1406
inet 10.10.10.91 --> 10.10.10.91 netmask 0xffffff00
With AnyConnect down and built in IPSEC up I can see ip address and also dns
servers in use via network pref gui and if config returns:
utun0: flags=8011 mtu 1280
You should try to get away from old Cisco IPSEC client if you can.
Are you using an ASA? On an ASA5510 with 8.2 software it is only $100 for a
250 user basic AnyConnect client license.
Brandon
On Wed, Feb 17, 2010 at 12:20 PM, kbyrd
Overall Rating: 5 (1 ratings)
Brandon Svec Wed, 02/17/2010 - 11:37
ifconfig is the equivilant command.
try man ifconfig for detailed info.
via GUI system prefs > network should give plenty of info too.
HTH,
Brandon
kbyrd Wed, 02/17/2010 - 11:48
Thanks for your response, Brandon. There's no detail - no IP address, DNS, domain search, etc.
cscotun0: flags=8850 mtu 1500
    closed
as opposed to my wireless NIC, for example:
en1: flags=8863 mtu 1356
    inet6 fe80::226:8ff:fee5:aec8%en1 prefixlen 64 scopeid 0x6
    inet 10.1.180.70 netmask 0xfffffc00 broadcast 10.1.183.255
    ether 00:26:08:e5:ae:c8
    media: autoselect status: active
    supported media: autoselect
Also, cat /etc/resolv.conf shows only the DNS servers from DHCP, not from VPN:
nameserver 199.5.86.29
nameserver 10.32.23.29
nameserver 199.5.86.10
Any other ideas?
Brandon Svec Wed, 02/17/2010 - 11:54
Are you using IPSEC or AnyConnect? If IPSEC are you using OS X built in
Cisco VPN client?
Brandon
On Wed, Feb 17, 2010 at 11:48 AM, kbyrd
kbyrd Wed, 02/17/2010 - 12:20
Brandon, I am using Cisco's IPSEC MAC client v 4.9.01.0180. I am also using anyconnect-macosx-i386-2.4.0202-k9.pkg.
I need to be able to support both IPSEC and AnyConnect.
Thanks again.
Correct Answer
Brandon Svec Wed, 02/17/2010 - 12:32
ifconfig returns:
Brandon
