Steven Smith Wed, 02/17/2010 - 12:27
Could you let me know more about what you describing?  I am not sure which Voicemail greeting options you are talking about.
SHeidemann Wed, 02/17/2010 - 12:40
Sorry about that,
Under voice view express> my options> greetings. .. you have all the options for alternate, meeting, vacation ect. Also when you settup your voicemail you have all the options there to activate and settup those options. I need to know how to remove all the extra options.. for end user simplicity.
Also there is a part 2 to this question I need an answer for.. I need to be able to restrict a user within a group from setting up the greetings to those groups, by setting controlled access to the GDM voicemail greetings. Seems that a user within a group can enter their user pin and change the greetings. That is too much user control.
Thank you
Steph
Marcos Hernandez Fri, 02/19/2010 - 10:17
There is no way to do either Stephanie. These options are tied to the Voicemail script in CUE, and that cannot be changed.
Marcos
SHeidemann Fri, 02/19/2010 - 10:59
Ok
I should be o'kay with no voicemail boxes on groups. Personal extentions in the groups will be utilized. This should work out fine.
Thank you.
