Our wireless controllers & WiSM's are deployed centrally.
We set up all our LWAPP AP's in H-REAP mode to take advantage of local switching, so that clients can access local resources w/o having to traverse all the way to the WiSM's and then back to the remote sites.
One WiSM cluster is deployed in the east coast, and one in the West Coast, because we were told the RTT for H-REAP should be <100ms.
We were told as long as we increase the EAP timer, H-REAP would work coast to coast.
My questions are:
Has anyone done it?
If it's true and works, exactly what variables and parameters should we set in terms of EAP?
(WISM) config>advanced eap ?
advanced eap ?
eapol-key-timeout Configures EAPOL-Key Timeout in seconds.
eapol-key-retries Configures EAPOL-Key Max Retries.
identity-request-timeout Configures EAP-Identity-Request Timeout in seconds.
identity-request-retries Configures EAP-Identity-Request Max Retries.
key-index Configure the key index used for dynamic WEP (802.1x) unicast key (PTK).
max-login-ignore-identity-response Configure to ignore the same username count reaching max in the EAP identity response
request-timeout Configures EAP-Request Timeout in seconds.
request-retries Configures EAP-Request Max Retries.
