AnyConnect SSL VPN client agent failed to launch
Feb 17th, 2010
I have a users PC that gets the following messages when trying to launch locally installed client...
"The VPN client agent failed to launch the client's user interface application" & "The VPN client driver has encountered an error"
AnyConnect VPN client ver 2.3.2016 installed on an XP machine.   Have tried deleting and re-installing the client but the same messages appear.
Thomas McLean Tue, 09/13/2011 - 01:42
I know this is an old issue but i experienced it today on my own laptop. I automatically remove the client after the session so i had nothing to uninstall..
my resolution was to install the client manually, and then re-run the anyconnect setup via the browser and everything came up.
Hopefully if someone gets the same issue again this will help.
Thomas
