Option to leave a VM while queueing
Feb 17th, 2010
Is this possible? How can I setup a script so that when a customer wants to leave a voicemail message, he just needs to press 1 at any time he wants while waiting in the queue.
See attached Test Script
In my script, if I want to leave a VM, I have to wait until I get to the "Get Digit String" step then press 1. However, once it passes this step, pressing one won't get me to the voicemail. I have to continue to wait until it gets back to that step again. What I really want is that I want, at any time, if I press 1, just get me straight to the voicemail. Any suggestion would be greatly appreciated.
Nathan Luk Thu, 02/18/2010 - 19:35
Not sure if this would work but you could try uploading your moh wav file as a prompt (will have to manually splice in every X seconds the voicemail prompt into the moh file) and just using that entire file as the prompt for your get digit step, set a timeout of 0 seconds for the get digit so if it hits the end of the file it doesn't have 3 seconds of silence while waiting for additional input. Make sure you set the Get Digit String to interruptible.
  • LABEL QueueLoop:
  • Get Digit String ( longMOHfile )
    • Success
      • Dequeue
      • Redirect to Voicemail
    • Timeout
    • Unsuccessful
  • Go to QueueLoop
Not entirely sure if that will work but give it a go.
ktran-anet Thu, 02/18/2010 - 19:50
Sounds like a good idea. Sure I will give it a shot and will let you know if that works or not. Thanks.
ktran-anet Fri, 02/19/2010 - 20:08
Hey, it worked. What I did was that I chopped my MOH into small pieces and used the Create Container step to stack then up together with my other prompts. It's a pain but I'm glad that it finally works the way I wanted. Thanks for your great suggestion Nathan.
