Level_15 message??
Ryboy3004
Hi all,m
sorry i dont know where else to go for support.  I have just changed computers..installed the networking drivers and re-introduced my local area connection (from a cisco 877 router).  It shows connectivity, however, now anytime i try to access the internet it comes up asking for a level_15 user password.  I have tried entering my router password and it tries to access the webpage as an extension of the router pathway.  Why is it doing this, i have never had any other problems with other computers.  Can anyone help me rectify this?
REgards
Ryan
10 Replies 10
Reza Sharifi
Hi Ryan,
Can you try using another computer or laptop to see if you still have the issue?
So, if you try to access for example google.com, it asks your for level 15 password?
Reza
Hi Reza,
It hasn't happened on another computer, although i have only tried the one that i originally had it setup for and plugged in another laptop.
Yes if i try to go to google.com for example it will then ask for the password and then when i enter it it will try top open the router/www.google.com and then just hangs....
Cheers
Hi Reza,
Cheers
It can be poosible that if you are using internet and it is asking for password then some sort of url filtering is there for http communication with authetication required to access inetrnet.
can you post your router configuration if possible
Ganesh.H
Hi Ganeshh
Sorry, I was unable to reply sooner as my router is at home, and for obvious reasons I am unable to access the internet yet. I have now setup two computers to run off the same router and so can hopefully answer your questions. I will open the router on the computer without any problems and try and provide you with the router config data. However, in the meantime...why is it that i am having problems on one computer but not the other. There must be something i am missing as far as configuring my computer to be able to access the internet..the router seems to be doing its job fine. Thanks for your help i am soo confused.
regards
Ryan
Is this what you are after?..
Building configuration...
Current configuration : 6197 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Podiatry
boot-start-marker
boot-end-marker
logging buffered 51200 debugging
logging console critical
enable secret 5 $1$TIkE$UEtFInuFb4.YrMlxF7pQJ0
no aaa new-model
resource policy
clock timezone PCTime 9 30
clock summer-time PCTime date Mar 30 2003 3:00 Oct 26 2003 2:00
ip subnet-zero
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool1
import all
network 10.10.10.0 255.255.255.0
dns-server 203.2.124.164 203.2.124.165
default-router 10.10.10.1
ip inspect name DEFAULT100 cuseeme
ip inspect name DEFAULT100 ftp
ip inspect name DEFAULT100 h323
ip inspect name DEFAULT100 icmp
ip inspect name DEFAULT100 netshow
ip inspect name DEFAULT100 rcmd
ip inspect name DEFAULT100 realaudio
ip inspect name DEFAULT100 rtsp
ip inspect name DEFAULT100 esmtp
ip inspect name DEFAULT100 sqlnet
ip inspect name DEFAULT100 streamworks
ip inspect name DEFAULT100 tftp
ip inspect name DEFAULT100 tcp
ip inspect name DEFAULT100 udp
ip inspect name DEFAULT100 vdolive
ip tcp synwait-time 10
no ip bootp server
ip domain name yourdomain.com
ip name-server 203.2.124.164
ip name-server 203.2.124.165
ip ssh time-out 60
ip ssh authentication-retries 2
crypto pki trustpoint TP-self-signed-3109695464
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3109695464
revocation-check none
rsakeypair TP-self-signed-3109695464
crypto pki certificate chain TP-self-signed-3109695464
certificate self-signed 01
3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33313039 36393534 3634301E 170D3032 30333031 30303035
32345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 31303936
39353436 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100C67F 304FC77C EA258D15 E8F64142 D5C9A640 49FA5E9A 75BBBEC3 B68D047C
B389F516 B016C99B 8EE39B06 B40F5F3D BC22B111 F0487609 0D641A0D 7A26BDD2
960FF16D DBD2B41A 8B94CF2E DC40958A AB60EA7C DAD27CA6 746B9D9B 9F7334EC
7B5405F2 20139A59 27821B8A 64067047 C896328E 53E71CF7 229F49E1 57312480
96890203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF 30220603
551D1104 1B301982 17506F64 69617472 792E796F 7572646F 6D61696E 2E636F6D
301F0603 551D2304 18301680 148B49AF E514EC82 84D84258 C4F445B0 8FF068BA
C3301D06 03551D0E 04160414 8B49AFE5 14EC8284 D84258C4 F445B08F F068BAC3
300D0609 2A864886 F70D0101 04050003 8181007A 6ABCE898 F9128548 D1B788AF
F17D9480 B6516DBE 2A450787 5ED563AD 7FAA6BE4 100E0B10 791624DE 25D0113B
7C90C24D 3F18CF0A 1A0674C8 756BEDA5 510763B7 ABD40C40 E9021C7E AD8FC7C5
27DDDA85 7FB3E803 DE22EA80 A8673043 1F435C21 8AB40351 BF19031A 0731149F
00AB426D 1AAE2ADE B0F6E211 BA145256 7AE16B
quit
username healthconnect privilege 15 secret 5 $1$KdeD$qgwX4lJPJx03bueaKZAzo.
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description $ES_WAN$$FW_OUTSIDE$
pvc 8/35
pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 10.10.10.1 255.255.255.0
ip access-group 100 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1412
interface Dialer0
description $FW_OUTSIDE$
ip address negotiated
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip inspect DEFAULT100 out
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname ryancausby@adam.com.au
ppp chap password 7 140411041810
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 100 remark auto generated by Cisco SDM Express firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by Cisco SDM Express firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 permit udp host 203.2.124.165 eq domain any
access-list 101 permit udp host 203.2.124.164 eq domain any
access-list 101 deny ip 10.10.10.0 0.0.0.255 any
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip host 0.0.0.0 any
access-list 101 deny ip any any
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
Cheers
Ryan
Just wondering if this screen capture helps at all...as i suspect that the issue is coming from here????
regards Ryan
And finally just in case it helps:
regards
Ryan
Hi Ryan,
Try going to Google using below IP address in your browser and test:
http://74.125.79.99/
Reza
i've noticed you got a dhcp server configured in your router. can you post your ipconfig/all on your laptop the one which is not able to go to the internet? make sure your tcp/ip is set to get an ip address automatically. try to ping to your lan gw 10.10.10.1 and then to any public ip afterwards. can you also post a show ip interface brief and do a direct connection on your laptop to any free enabled router ports and do the ping tests again.
Thankyou everyone, I think it is well beyond me, I think I will have to pay someone to help me. Thanks for your time. I think I need to teach myself a bit more before I take this on.
