Reza Sharifi Wed, 02/17/2010 - 19:51
  • Cisco Designated VIP,
    2017 LAN
Hi Rc,
Make sure to follow the config guide (below) to deploy eFSU for your VSS system.  It works really well if you follow it step by step.  You should not have down time.  Just one thing to remember that eFSU works well when you are upgrading from a major release to another major release and not a minor to major.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/issu_efsu.html#wp1042706
Good luck.
Reza
rc.castillo Wed, 02/17/2010 - 21:28
HI Reza,
1. Router> enableway to
2.copy tftp bootflash:s72033-advipservicesk9-mz.122-33.SXI2a.bin
  copy tftp slavebootflash:s72033-advipservicesk9-mz.122-33.SXI2a.bin
3.show version | inc image
  show bootvar
  show redundancy
  show issu state detail
4. issu loadversion bootflash:s72033-advipservicesk9-mz.122-33.SXI2a.bin
5. show issu outage slot all
6  issu-runversion
7. issu acceptversion
8. issu commitversion
9. show redundancy
   is this the right implement efsu? and what do you mean by minor to a major release? im upgrading from SXI to SXI2a
Reza Sharifi Thu, 02/18/2010 - 05:43
    2017 LAN
rc.castillo wrote:
HI Reza,
  show bootvar
  show redundancy
6  issu-runversion
9. show redundancy
Hi RC,
By minor to major, I mean if you are going for example from SXI2a SXI3 is does not work, but if you are going from SXI1 to SXI3 it or SXI2 to SXI3 it works fine. Since you are running SXI, I recommend going to SXI3 (latest version on CCO). and not SXI2a, because there a few bug fixes in SXI3 and seems to a good image. BTW, do not use SXI2 at all as it is a differed version.
Reza
princes.lobo Thu, 02/18/2010 - 18:14
Hi Reza,
     Is the config right with regards to performing EFSU
Reza Sharifi Thu, 02/18/2010 - 19:40
    2017 LAN
Hi RJ,
You need to copy the IOS into sup-bootdisk (primary VSS) and slavesup-bootdisk (backup VSS) and not into the boot flash, because the boot flash is only 64Mb by default and the IOS is 155Mb, so it will not fit into the boot flash.
Good Luck
Reza
