sh shun statistics show all interfaces OFF at ASA.
Feb 17th, 2010
I have ASA 5510 (8.0.2), ASDM 6.1 and ASA-SSM-10 6.1.
When I run "sh shun statistics" at ASA, I receive the folloing:
outside=OFF, cnt=351
inside_backup=OFF, cnt=0
dmz=OFF, cnt=26059
inside=OFF, cnt=18414
Does it mean that Shunning is not working. If so, how can I enable it?
Thanks in advance for the help.
Semih
Panos Kampanakis Thu, 02/18/2010 - 13:28
It means you are currently not shunning a host.
Try putting a manual shun in and check then.
Also use "sh shun" to show you current shuns.
I hope it helps.
PK
Related Content
