Configuring IPM 4.1
Feb 17th, 2010
     When i am configuring IPM 4.1 for udp jitter operation. i am getting the error message as "Only responder enabled devices permitted for selected operations" , but i have configured the "ip sla monitor responder" command both in source and target devices. I have attached the screen shot of the error message also. Please explain me how to overcome the problem.
Joe Clarke Thu, 02/18/2010 - 09:51
You need to make sure your target device is seen as a responder-enabled device by IPM.  If you enabled the responder after adding the device to IPM, delete the device from IPM, and add it again.
