WCS redundancy
Answered Question
Feb 17th, 2010
In config guide V6.0 WCS redundancy is described. Has anyone used this in real-life?
http://www.cisco.com/en/US/partner/docs/wireless/wcs/6.0/configuration/guide/6_0admin.html#wp1132580
> What are the triggers for activating the failover
> how much time is needed to switch back form secondary to primary WCS
> Is it indeed easy to configure, easy to maintain and does everything work properly:-)
THX
Goen
Correct Answer by sschmidt about 6 years 11 months ago
The healthmonitor on the secondary monitors the primary server for things like hardware failure, network failure, software failure and database failure.
Depending on whether it is configured for automatic or manual failover the switchover happens automatically or the administrator initiates failover.
Once the outage is over you can failback to the primary which basically takes as long as starting WCS.
It isn't hard to configure and in the lab and the customers I have seen using it the feature works well.
Overall Rating: 5 (1 ratings)
Correct Answer
sschmidt Thu, 02/18/2010 - 06:08
Related Content
Trending Topics - Security & Network
