02-17-2010 11:37 PM - edited 03-19-2019 12:29 AM
Hello Together,
I would like to know whether it is possible to perform the synchronization of the MWIs automatically between Callmanager and Unity? I could just find the common "Run" Buttom under my phone system. The cisco documentation just mentions this.
Thanks and best regards
Solved! Go to Solution.
02-18-2010 05:43 AM
Hi there,
This is most possible
Cisco Unity Connection Task Management Tool
The Task Management pages list a variety of system maintenance and troubleshooting tasks that Cisco Unity Connection automatically runs on a regular schedule. Tasks can be run at the same time as backups and anti-virus scans.
The default settings and schedules for each task are optimized for functionality and performance. We recommend that you not change the default settings and schedules.
Caution
Some tasks are critical to Connection functionality. Disabling or changing the frequency of critical tasks may adversely affect performance or cause Connection to stop functioning.
To Access the Task Management Tool
Step 1
In Cisco Unity Connection Administration, expand Tools.
Step 2
Click Task Management.
Selet the "Resynchronize MWIs On All Phone Systems" task
And set schedule (usually something like 3:00am)
Cheers!
Rob
02-18-2010 05:43 AM
Hi there,
Caution
Step 1
Step 2
Cheers!
Rob
02-18-2010 06:25 AM
Thanks, Rob. It was too obvious, that's why I couldn't find it.
02-18-2010 07:15 AM
Too True,
I know the feeling all too well my friend
I can't see "the forest for the trees" half the time, that's why
it's always good to have someone else looking as well.
Cheers!
Rob
