Feb 18th, 2010
I would like to know if it is possible of there is a document with the guidelines on how to configure/create the following configuration:
-          Headquarters with two routers 1800 (let’s call them R1 and R2)
-          Branch offices with 800 routers (R3 and R4)
The router R2 must be the one with more priority towards VPN conections. In addition to that R1 router must give Internet connection to user on Headquarter’s LAN.
Branch offices must connect through IPSec tunneling (NO GRE) to the headquarters R1 with redundant availability in case of failure through R2.
There are remote clients of Windows that through IPSec VPN must be able to tunnel to routers R1 and R2
The idea is to have redundancy on the VPN’s and that, in addition, we can have remote clients that connect through Cisco VPN client.
Thanks a lot,
