02-18-2010 01:40 AM - edited 03-15-2019 09:28 PM
I don´t have enough experience with VoIP and I need your help.
I have a Cisco 3845 voice gateway with version 12.4(20)T2, I have 2 DSP PVDM2-64. This gateway handle 300 phones approximately
The conf for conferences and transcoding is:
dspfarm profile 2 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
associate application SCCP
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 9
sh dsp dsp all shows:
C5421 1 01 {medium} 23.8.0 IDLE idle 0 0 none NA 0 0/0
C5421 1 02 {medium} 23.8.0 IDLE idle 0 0 none NA 0 0/0
C5421 1 03 {medium} 23.8.0 IDLE idle 0 0 none NA 0 0/0
C5421 1 04 {medium} 23.8.0 IDLE idle 0 0 none NA 0 0/0
C5421 2 01 {medium} 23.8.0 IDLE idle 0 0 3/0/0 NA 0 0/0
C5421 2 02 {medium} 23.8.0 IDLE idle 0 0 3/0/1 NA 0 0/0
C5421 2 03 {medium} 23.8.0 IDLE idle 0 0 3/0/2 NA 0 0/0
C5421 2 04 {medium} 23.8.0 IDLE idle 0 0 3/0/3 NA 0 0/0
C5421 3 01 {medium} 23.8.0 IDLE idle 0 0 none NA 0 0/0
C5421 3 02 {medium} 23.8.0 IDLE idle 0 0 none NA 0 0/0
C5421 3 03 {medium} 23.8.0 IDLE idle 0 0 none NA 0 0/0
C5421 3 04 {medium} 23.8.0 IDLE idle 0 0 none NA 0 0/0
C5421 4 01 {medium} 23.8.0 IDLE idle 0 0 none NA 0 0/0
C5421 4 02 {medium} 23.8.0 IDLE idle 0 0 none NA 0 0/0
C5421 4 03 {medium} 23.8.0 IDLE idle 0 0 none NA 0 0/0
C5421 4 04 {medium} 23.8.0 IDLE idle 0 0 none NA 0 0/0
Questions:
1. Can I release this allocation, if so how can I proceed?
2. I haven´t have configured MTP, is it necessary?
3. How can I calculate the number of participants per session with this conf? Is it 2 sessions per DSP or 2 session totally?
If you need additional information please let me know.
Many thanks for your help, really appreciated.
Regards.
Solved! Go to Solution.
02-18-2010 11:12 AM
Table 6 covers all this
Table 6 Theoretical System Capacities for One DSP
You might have 2xPVDM2-64 but you're using only 1 DSP for CFB, so that's
IF ONLY G711 enabled on dspfarm profile:
8 sessions
(8 x 8 = 64 conferees)
If ONLY G729 or G729 is included in the codec list:
2 sessions
(8 x 2 = 16 conferees)
Number of sessions per DSP depends on codecs enabled.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
02-18-2010 06:21 AM
1. Decrease the number of sessions
2. Depends, read this:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/media.html#wp1046314
3. To learn how to calculate all that read this:
02-18-2010 07:47 AM
Hey Java,
Thank you for yor answer,
I follow having a doubt, when you say:
Sessions = 1 CFB with X participants
Number of sessions depend on codecs you enabled.
I don´t undestand very well this part, so in my case I have 2 PVDM-64 and I use G711 and G729.
Cisco says for 4 PVDM2-64:
g711
50 sessions
(400 conferees)
and g729
32 sessions
(256 conferees)
in both cases I get the same result, in my case with 2 sessions = 16 conferees as maximun. Is this correct? I think I don´t know calculate the number of sessions..
Can you help to clarify this point.
Many thanks again for your help Java.
Paul.
02-18-2010 09:22 AM
If it helps you can use this calculator on the cisco website. but you will need a CCO account.
http://www.ciscosystems.com/cgi-bin/Support/DSP/dsp-calc.pl
Varun
02-19-2010 02:15 AM
Hi Varun,
Thanks for your answer.
Yes I have a CCO account and I know the DSP calculator but my problem was I didn´t undestand some points regarding conferences in Cisco guides.
Tks again.
Paul.
02-18-2010 11:12 AM
8 sessions
2 sessions
java
02-18-2010 11:44 PM
Hi Java,
Many thanks for your help.
This answer solved my doubt.
Paul.
