Giuseppe Larosa Thu, 02/18/2010 - 02:51
Hello Mohamed,
>> are there any way t to aggregate  2 DS3 other than multilink PPP
I would suggest to use them as two L3 parallel links
flow based CEF load balancing provides good results with usual traffic patterns
Hope to help
Giuseppe
mohamed-elsherif Fri, 02/19/2010 - 00:32
dear Mr gisular
my problem actually that i have two 7200 router that connected through two DS3s one of them is VXR the other is NPE-g2 , the VXR router is connected to ADSL DSLAMs the other is connected to the Raduis server and the are already loading balancing using EIGRP , but the problrm is when the clients tries to connect they authenticate two times through two different interface which leads to wrong information on my radius , and when i used multiPPP
the CPU uitltization was very high on ,my router
now i\m searching for a way to load balance and in the same time use bundle interface that can make clients authenticate from same IP address as source interface
thanks alot
Giuseppe Larosa Fri, 02/19/2010 - 01:49
Hello Mohamed,
I think a possible solution would be to force the source of radius packets to be for example a loopback interface
ip radius source-interface ?
this should make consistent the way they appear to the radius server
Hope to help
Giuseppe
