command to overwrite current running config on cat6500
Feb 18th, 2010
I learnt some time ago how to replace the current running config with a complete new config on my cat 6500 rather than merging them like what normally happens, Is this right, that they normally merge ?
is it the config replace command ?
Ganesh Hariharan Thu, 02/18/2010 - 03:36
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
The Configuration Replace and Configuration Rollback feature provides the capability to replace the current running configuration with any saved Cisco IOS configuration file. This functionality can be used to revert to a previous configuration state, effectively rolling back any configuration changes that were made since that configuration file was saved.
Check out the below link for more information
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t7/feature/guide/gtrollbk.html#wp1085347
Hope to help
Ganesh.H
