SNMP OID for IP NAT translations
Feb 18th, 2010
I am looking for the SNMP OID to monitor the sh ip nat translations on a cisco 6500.
Can anyone please know if this is available.
Victor
Overall Rating: 3 (1 ratings)
Joe Clarke Thu, 02/18/2010 - 09:54
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What version of IOS is this switch running?
victor_87 Fri, 02/19/2010 - 04:18
The IOS version is 12.2
===> 122-18.SXF14.
Joe Clarke Fri, 02/19/2010 - 07:45
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I need to see the "show version" output.
victor_87 Sat, 02/20/2010 - 06:52
hi Joe,
Sh ver below
Cisco IOS Software, s3223_rp Software (s3223_rp-IPSERVICESK9_WAN-M), Version 12.2(33)SXH4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Sun 09-Nov-08 23:57 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
System returned to ROM by s/w reset  EDT (SP by power-on)
System restarted at 01:43:21 EDT
System image file is "sup-bootdisk:s3223-ipservicesk9_wan-mz.122-33.SXH4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C6506-E (R7000) processor (revision 1.0) with 458752K/65536K bytes of memory.
Processor board ID
R7000 CPU at 300Mhz, Implementation 0x27, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
22 Virtual Ethernet interfaces
49 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Joe Clarke Sat, 02/20/2010 - 10:48
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This image does not support the CISCO-IETF-NAT-MIB which provides details about active translations.
victor_87 Sun, 02/21/2010 - 09:08
Thanks Joe,
Please tell me which image supports the MIB, will plan on Upgrading if required.
Victor
