Cisco 7921G or 7925G User Certificates - Private Key Storage
kfarrington
Level 3
Level 3
Hi All,
When you generate a CSR on the 792x phone,  a CSR would generally generate a private and public key, include the public key in the CSR and then you will send that off to your CA.  I think that is correct
Question 1:  Where is the private key stored on the phone and what is it?  Its not like you can associate your own private key (ie passphrase) as the private key?  It does not give you that option?
Question 2: Is the private key and user cert exportable?  I hope not?
Many thx indeed,
Ken
migilles
The private key is generated during the CSR and stored locally in flash, which it is not exportable.
