ASA and H.323
Feb 18th, 2010
Hello, colleagues,
I have some problems with configuring H.323 on ASA 5505 Version 7.2(1)
At the inside network there is a H.323 gateway with address
Static NAT is made that outside address X.X.X.X is forwarded to the inside address:
static (inside,outside) X.X.X.X netmask
ACL allow to pass traffic from particular H.323 gateways at the outside network.
There are inspect commands:
policy-map global_policy
class inspection_default
  inspect h323 h225
  inspect h323 ras
I run :
debug h323 h225 asn
debug h323 h225 event
debug h323 h245 asn
debug h323 h245 event
I see that ASA accept H.225 SETUP message, forward it to the inside address, received CALL PROCESSING from inside gateway, but don't forward it to the outside originating gateway.
After a period of time the outside originating gateway sends releaseComplete.
How to fix this issue? Is it possible that H.323 gateway at an inside network behind ASA works correctly with outside gateways?
I attached the debug output from the ASA.
Panos Kampanakis Thu, 02/18/2010 - 13:17
7.2.1 had some h323 inspection issues.
I would suggest to upgrade and try again.
I hope it helps.
supro Thu, 02/18/2010 - 22:07
Thank you, guys!
I will try to upgrade and post the results here.
supro Fri, 02/19/2010 - 00:41
I have upgraded to Version 8.2(2), but it did not help
The behaviour is the same.
Going to change ASA to transparent mode operations to avoid NATing of H.323
Thanks for the answers.
Should anybody have experience or ideas about this issue, post here, please.
supro Wed, 02/24/2010 - 06:46
Colleagues, the problem was with H.323 gateway, not with ASA.
Now it is solved.
Kureli Sankar Wed, 02/24/2010 - 14:04
Thanks for letting us know. If it broke even after the upgrade - we were at a loss.
