SA520W SSL VPN signed self cert problem
Feb 18th, 2010
Please forgive me if this is a dumb question or if I am fundamentally confused, but I have pored over the manual, forum, and web.  Very simply I need a trusted third party to sign my CSR and then for the SA520W to accept it as the active self certificate.  In principle this is straightforward but I cannot figure out how to make this work in practice.  Two examples.
1) GoDaddy:  they require a 2048 bit signature and the router only generates 1024.  I can generate my own CSR with OpenSSL but then am unable to upload my 2048 bit key to the router, and thus the signed certificate is not accepted
2)  Verisign.  They will take the router's 1024 bit signature, but they require lots of fields in the CSR, like country and state, that are not supported by the router's generate CSR function.  Thus Verisign will not accept the CSR.
Is there any way to get the router to accept a CSR signed by GoDaddy?  Or any CA?
Thanks in advance.
Andy
