help restoring default registers in the 0x2xxx range
Feb 18th, 2010
i recently accidentally changed my configuration register to 0xfe3f on a cisco 831 router and reset it, i thought this would help on refreshing the flash since i had previously lost my IOS from flash and all available images i have on other c831 routers are larger than my available memory.
I tried the break function (ctrl+space bar) but all i got was more of jumbledup output on my hyper terminal screen.
MäñôÙ4Á¼a{ˆ puhæ pý$áûaâø\
please help me with this its really important to me thta i get it resolved
Ganesh Hariharan Thu, 02/18/2010 - 09:20
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Check out the below link for recovery method in cisco routers series 800.
http://www.cisco.com/en/US/products/hw/routers/ps380/products_password_recovery09186a00800942bc.shtml
If helpful do rate the post
Ganesh.H
mloopsmloops Fri, 02/19/2010 - 01:37
Thankyou ganeshh for your response, am going to check it out and i will let you know how it goes.
