02-18-2010 08:22 AM - edited 03-06-2019 09:46 AM
I have a network with a mixture of C3560 and C2900 series switches. As of this week we are lossing the gig port / trunk ports on all of the C2900 series switches. This ranks from WS-C2950, WS-C2950G, WS-C2960, 24 - 48 ports, to PoE and non-PoE. I currently have around 60 C2900 series switchs.
The C3560 series has no problems but one location that only has (2) C3560. The gig port / trunk are no longer lit and shutdown. I have not tried to console into one that was down to see what the error was. I have just unplugged the switches and plug them back in, after they boot the system is up and running.
Is there a know problem with the IOS on the C2900?
I am just confused that is only affecting them and not the C3560, C6509 or C4507.
02-18-2010 08:31 AM
It sounds like they are going into errdisable. To find out what is really going on, you will have to connect a console, log into them and interrogate them in the error condition.
Perhaps you could post the config of the trunk ports? That might give us a clue. "Is there a know problem with the IOS on the C2900?" is a bit too generic a question to answer sensibly.
Kevin Dorrell
Luxembourg
02-18-2010 09:06 AM
What is the status of port when it goes down in 2960 switch and as suggested by Kevin please share your trunk port configuration.
Ganesh.H
02-18-2010 01:43 PM
You can also test if you have a cable problem using the built-in TDR tester of the 3560.
02-22-2010 05:16 AM
Sorry for just now getting back with you.
The trunk configuration is as follows
interface GigabitEthernet0/1
switchport mode truck
switchport nonegotiate
The cables test fine. There is a mixture of fiber and cat5e for the trunk lines.
I was unable to console the switches because my boss was out first thing in the morning and unplugged and plugged them back in to get the network back up. I was told that the trunk interface was not lit.
I have 8 building connecting to HQ via a Gi fiber. The network is flat except for one building on its own VLAN and all the switches are connected to VLAN 1 class C. I also have one VLAN for my Cisco VoIP network. I also have the Cisco WIFI 4400 series and AP on the flat network.
I looked on the web but could not find anything about this issue. I just find it strange that it only affected the 2900 series switches execept for one location that had (2) 3560. I was trying to see if there was a know issue so I could report back with the error and possible solution.
