1240ag Bridge Issue
Feb 18th, 2010
I have 2 1240ag's 1 in root bridge mode and the other setup as workgroup bridge.  I am bridging the main building with another building.  It is working, but I can only ping from the wgb location.
Milton Tizoc Mon, 03/01/2010 - 10:33
Hi, if they are associated they have to work like this, don't you have some issues with firewall or some thing like that? if not, can you post the config of the two ap's and the show dot11 associations for both?
Best Regards,
Milton Tizoc.
Scott Fella Sat, 03/06/2010 - 08:20
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
You should try to setup one end as an access point and the other as a WGB.  Or else just do root-bridge to non-bridge if the remote end is going to be connected to a switch.  If you do the later, you can do the bridge link on one band and setup the other band for wireless access also.
