William Bell Wed, 02/24/2010 - 20:05
  • Purple, 4500 points or more
Depends on what you mean when you say "AXL".  If you are referring specifically to the AXL API that you would use to execute SQL queries on the database or access objects like "updateLine" then the answer is no.  That particular API is not used for Real-Time information.  However, there are two other APIs that can be used to get real time information.  One is called RIS Port and this would be the API one would use to get registration status, IP address information, etc. for devices that are registered (or unregistered as the case may be).  If you are familiar with devicelistx, RISPort is the replacement (more or less).
There is also the AXL Serviceability API that can be used to grab perfmon information.  I suspect this is closer to what you would be looking for than RISPort.  I have not worked with the AXL Serviceability API myself but I use AXL for administrative functions and the RISPort.   The data structures for AXL Serviceability API and RISPort are noticeably different than the Admin AXL API but I think that is a matter of getting hang of using them.  But that is just my guess.
You can get information on the AXL Serviceability API here:
http://developer.cisco.com/web/sxml/home
You will need a CCO account to access the URL.
HTH.
Bill
Please remember to rate helpful posts.
